Diff Oil ??? EP or not EP ?
(08-08-2022, 10:26 AM)Graham Barker Wrote: There must be a story behind your comment about 3 in 1. Are you going to enlighten us?
It might - or might not - be a Colin Chapman quip when asked how to reduce oil drag in the back axle. Early axles were filled with a glutinous mixture of grease and oil - hence the sealing arrangements to prevent this from escaping down the axle tubes and contaminating the brakes were either rudimentary on nonexistent. It's ages since I had an axle apart - what were the sealing arrangements of the later screw-in and long flange types?
Diff Oil ??? EP or not EP ? - by flywheel1935 - 06-08-2022, 01:27 PM
RE: Diff Oil ??? EP or not EP ? - by Alan Osborne - 06-08-2022, 04:29 PM
RE: Diff Oil ??? EP or not EP ? - by flywheel1935 - 06-08-2022, 04:50 PM
RE: Diff Oil ??? EP or not EP ? - by Colin Morgan - 06-08-2022, 05:37 PM
RE: Diff Oil ??? EP or not EP ? - by flywheel1935 - 06-08-2022, 07:03 PM
RE: Diff Oil ??? EP or not EP ? - by Colin Morgan - 06-08-2022, 09:18 PM
RE: Diff Oil ??? EP or not EP ? - by Parazine - 06-08-2022, 10:46 PM
RE: Diff Oil ??? EP or not EP ? - by Ron Hayhurst - 08-08-2022, 10:07 AM
RE: Diff Oil ??? EP or not EP ? - by Reckless Rat - 08-08-2022, 12:40 PM
RE: Diff Oil ??? EP or not EP ? - by Tony Griffiths - 08-08-2022, 04:00 PM
RE: Diff Oil ??? EP or not EP ? - by Steve Jones - 08-08-2022, 04:26 PM
RE: Diff Oil ??? EP or not EP ? - by Colin Wilks - 08-08-2022, 06:15 PM
RE: Diff Oil ??? EP or not EP ? - by Hedd_Jones - 08-08-2022, 06:35 PM
RE: Diff Oil ??? EP or not EP ? - by Steve Jones - 08-08-2022, 06:57 PM
