01-08-2022, 09:19 PM
The cables to the switch are so thick and heavy you won't move the switch until they are undone from the back of it.
It is easy enough to remove the whole starter assembly, it is only a bolt on each side, into the crank-case.
It is a bit heavy, though, getting it out from under the dash.
