Ruby Brake Cross-shaft
Hi
It's probably worth noting that brackets for the earlier cars with the self aligning bearings are very similar to the semi-girling ones, and the 8 chassis fixings are in the same place. The only difference is the diameter and detailed shape of the central hole, which won't matter if you are modifying them anyway to make a new bearing.
The diameter of the semi-girling inner shaft is 1 inch at the bearing ends.
Ruby Brake Cross-shaft - by jamessmith1797 - 30-07-2022, 07:53 PM
RE: Ruby Brake Cross-shaft - by jamessmith1797 - 30-07-2022, 08:21 PM
RE: Ruby Brake Cross-shaft - by Dennis Nicholas - 30-07-2022, 10:24 PM
RE: Ruby Brake Cross-shaft - by Tony Griffiths - 30-07-2022, 11:18 PM
RE: Ruby Brake Cross-shaft - by jamessmith1797 - 31-07-2022, 08:45 AM
RE: Ruby Brake Cross-shaft - by Hugh Barnes - 31-07-2022, 09:24 AM
RE: Ruby Brake Cross-shaft - by John Cornforth - 31-07-2022, 09:51 AM
RE: Ruby Brake Cross-shaft - by jamessmith1797 - 31-07-2022, 06:15 PM
RE: Ruby Brake Cross-shaft - by John Cornforth - 31-07-2022, 07:43 PM
RE: Ruby Brake Cross-shaft - by jamessmith1797 - 01-08-2022, 07:39 PM
RE: Ruby Brake Cross-shaft - by John Cornforth - 01-08-2022, 09:05 PM
