31-07-2022, 05:12 PM
Getting ready for an outing with Rekkers, slight adjustment to 3rd brush dynamo - nice charge rate of 8 amps, cutout contacts cleaned, pull in voltage checked, drop out volts checked, cleaned points.
Went out for a run and a coffee - ammeter going wild, err ? Quick back and forth on the ignition switch and problem gone. Phew, glad that wasn't another job for the list.
Now just need to grease all round, check half shaft nuts and prop shaft support assembly. Looking forward to the run out.
Bob
Bob
