31-07-2022, 09:24 AM
(This post was last modified: 31-07-2022, 09:25 AM by Hugh Barnes.)
The thing to bear in mind, James, is the cross shaft needs to be quite a 'sloppy' fit in the housings. The chassis flexes so much that if the cross shaft is held too tightly, it binds when the car moves around on the road... Tony's suggestion of the self aligning bearings may overcome that, but just so you are aware of that aspect...
hth...
hth...
