28-03-2018, 11:25 AM
(28-03-2018, 10:34 AM)bob46320 Wrote: I use a 1.0 ohm on my '32 RN. The wire wound resistor around the ign light is 15 - 20 ohm.
BobH
On my RP I use a 22ohm 0.6 watt resistor to replace the wire wound resistance wire on the ingnition warning lamp, the value of the series resistance mounted on the under side of the CFR cutout is 3 ohm.
Hope this helps.
Bill in Lincoln.
