DEL 1929 dynamo
this one has 4 setscrews in the brush section under the brush 'ring', holding the outer housing on. It's neat as the D terminal stays with that centre section. In fact, for a two brush conversion, I'm thinking that the field connections can stay entirely with the fields and main body (isolated F connector emerges from it), as the second end can be earthed right in place somehow and the 2nd brush made to earth on the brush body. Will make disassembly very easy and far fewer trailing wires to catch on a spinning armature...
Howard - I can't see why you couldn't, looking at this? If you have the early variant. The odd thing is that one of the four nuts is internal to the housing where you stick the distributor. Mine wasn't connected there - just the nut sitting in the hole.
DEL 1929 dynamo - by JonE - 15-07-2020, 10:56 AM
RE: DEL 1929 dynamo - by Parazine - 15-07-2020, 11:35 AM
RE: DEL 1929 dynamo - by JonE - 15-07-2020, 11:46 AM
RE: DEL 1929 dynamo - by Bob Culver - 15-07-2020, 09:05 PM
RE: DEL 1929 dynamo - by JonE - 16-07-2020, 09:20 AM
RE: DEL 1929 dynamo - by Parazine - 19-07-2020, 02:10 PM
RE: DEL 1929 dynamo - by JonE - 06-04-2021, 07:53 AM
RE: DEL 1929 dynamo - by AustinWood - 06-04-2021, 09:03 AM
RE: DEL 1929 dynamo - by Parazine - 06-04-2021, 10:09 AM
RE: DEL 1929 dynamo - by JonE - 06-04-2021, 10:19 AM
RE: DEL 1929 dynamo - by Parazine - 06-04-2021, 10:41 AM
RE: DEL 1929 dynamo - by Bob Culver - 06-04-2021, 08:42 PM
RE: DEL 1929 dynamo - by JonE - 07-04-2021, 03:40 PM
RE: DEL 1929 dynamo - by JonE - 09-04-2021, 06:41 PM
RE: DEL 1929 dynamo - by JonE - 16-07-2022, 08:14 PM
RE: DEL 1929 dynamo - by Lowespeed - 17-07-2022, 12:17 PM
RE: DEL 1929 dynamo - by Howard Wright - 17-07-2022, 12:24 PM
RE: DEL 1929 dynamo - by JonE - 17-07-2022, 12:25 PM
