Austin Big Seven starting problem
If the plugs are soaking wet it suggests that there's an ignition problem somewhere. If there carb has been overfuelling and the plugs have been running rich then the spark is likely to break down under compression. Have you tried a different set of plugs?
Austin Big Seven starting problem - by Thowdfella - 26-03-2018, 07:57 AM
RE: Austin Big Seven starting problem - by Reckless Rat - 26-03-2018, 02:52 PM
RE: Austin Big Seven starting problem - by Colin - 27-03-2018, 04:17 AM
RE: Austin Big Seven starting problem - by NickB - 31-03-2018, 08:27 AM
