Austin Big Seven starting problem
(26-03-2018, 12:29 PM)L Colin Wilks Wrote: I hope I'm not teaching granny to suck eggs here, but have you confirmed the action of the float bowl needle valve is correct? If it's not closing correctly excess fuel will enter the carb via the orifice opposite the choke spindle and will keep on coming.
Thanks for that but yes. When I fill the carb by using the pump lever after about three pumps it stops and won't put any more in. Also I have just had the needle valve out and checked it and it's fine, in fact it's a new one. If I take the plugs out they are soaking wet. I put a new condenser in a little while ago so just to prove it's not that I pit the old one in but no difference.
Austin Big Seven starting problem - by Thowdfella - 26-03-2018, 07:57 AM
RE: Austin Big Seven starting problem - by Thowdfella - 26-03-2018, 01:31 PM
RE: Austin Big Seven starting problem - by Colin - 27-03-2018, 04:17 AM
RE: Austin Big Seven starting problem - by NickB - 31-03-2018, 08:27 AM
