Block spacer ugently required
Be warned Solid copper gaskets on an A7 engine do not appear to be a good idea unless on a dry decked engine. Perhaps it was just me but I tried several times and could never get them to seal the water ways so always experienced seepage, I tried several gasket sprays and goops recommended by racers of bigger engined cars.. I think that the clamping forces at the low head torques we use may be insufficient. If anyone has had positive experience's on an Austin 7 engine I would be interested to learn from them.
PS Hugh, I have not found the block spacers hard to make from Aluminium sheet, it is probably within the capability's of most Austin seven owners
Block spacer ugently required - by Hugh Barnes - 01-07-2022, 04:27 PM
RE: Block spacer ugently required - by dickie65 - 01-07-2022, 05:28 PM
RE: Block spacer ugently required - by Ian Williams - 06-07-2022, 09:15 PM
RE: Block spacer ugently required - by squeak - 07-07-2022, 01:11 PM
RE: Block spacer ugently required - by JoeRowing - 07-07-2022, 10:07 PM
