24-03-2018, 08:30 PM
ARQ chassis numbers run roughly from 189xxx to 243xxx. Original engine numbers (which have an "M" prefix) are usually several hundred higher than the chassis number and the "Car number should be between ARQ 1 and ARQ 3xxxx. a7ca.org/downloads/QuoteThisNumber.pdf will help you to find them. If the numbers on the car don't look right, ask more questions! I don't know how it works in the US, but it can be a problem over here. Good luck, Mike!
