Block spacer ugently required
Take 25 thou off the piston crowns in a lathe is a feasable option
I have taken 20 thou off the top of pistons in the past on a high reving engine.
I have also hand made a heavy duty block gasket from some thick gasket material which was about 30 thou compressed.
There is also the option of fitting two head gaskets ( not the best solution though as there is more chance of failure )
Where abouts in the world are you ??
Block spacer ugently required - by Hugh Barnes - 01-07-2022, 04:27 PM
RE: Block spacer ugently required - by dickie65 - 01-07-2022, 05:28 PM
RE: Block spacer ugently required - by squeak - 07-07-2022, 01:11 PM
RE: Block spacer ugently required - by JoeRowing - 07-07-2022, 10:07 PM
