An "interesting" boat-tail two-seater....
#56
hi mike,
the headlamps situation is easy. and a stoopid one for people to pick up on.
all the cars wings are original, with holes in the correct position.
the wings are bolted to the stays in three places.
if you fit the headlamp brackets to the lower and middle holes, it brings the headlamps close enough to the bonet, that you know you are going to keep catching the bonet and scratch or chip the paint.
so you mount the lamps on the middle and top hole. the lamps are then a bit higher. but further away from the bonet.
and then you dont keep damaging things.
tony.
RE: An "interesting" boat-tail two-seater.... - by Tony Betts - 28-06-2022, 06:14 PM
