  • 2 Vote(s) - 3 Average
Odd noise
#31
(24-03-2018, 09:46 AM)Buairidh Dunford Wrote: What do the lower dynamic ratings mean in the application please Tony?
A lower capacity bearing will give a lower calculated nominal design life in revolutions to fatigue failure on a ring or rolling element.
It is used to design any bearing application.
The basic dynamic capacity is the constant load under which the bearing will attain a nominal life of 1 million revolutions.   This is only a nominal life-  some may fall below it and 50 % will last over 5 times longer.
I quote the figures to indicate why Austin designers would have chosen the Angular Contact Ball front and Roller Bearing rear  for the crankshaft - the alternate bearings suggested would lead to a lower bearing life but if this is acceptable then it is alright to substitute.
If you may remember the pinion support bearing went from a roller bearing to a ball bearing and subsequently back to a roller bearing- I would think because of the unacceptable reduced life of the ball bearing.
Tony.
Odd noise - by Charles P - 21-03-2018, 08:36 PM
RE: Odd noise - by Alan - 21-03-2018, 08:50 PM
RE: Odd noise - by Ruairidh Dunford - 21-03-2018, 09:10 PM
RE: Odd noise - by Alan - 21-03-2018, 09:24 PM
RE: Odd noise - by Ruairidh Dunford - 21-03-2018, 09:39 PM
RE: Odd noise - by Ian Williams - 21-03-2018, 10:02 PM
RE: Odd noise - by Charles P - 21-03-2018, 10:19 PM
RE: Odd noise - by Alan - 21-03-2018, 11:11 PM
RE: Odd noise - by Charles P - 21-03-2018, 11:26 PM
RE: Odd noise - by Ian Williams - 22-03-2018, 01:13 AM
RE: Odd noise - by Albert S - 22-03-2018, 07:38 AM
RE: Odd noise - by Dave Wortley - 22-03-2018, 09:04 AM
RE: Odd noise - by Charles P - 22-03-2018, 09:12 AM
RE: Odd noise - by Charles P - 22-03-2018, 12:42 PM
RE: Odd noise - by Austin in the Shed - 22-03-2018, 01:52 PM
RE: Odd noise - by Ruairidh Dunford - 22-03-2018, 12:54 PM
RE: Odd noise - by Ruairidh Dunford - 22-03-2018, 12:55 PM
RE: Odd noise - by JonE - 22-03-2018, 12:55 PM
RE: Odd noise - by Albert S - 22-03-2018, 01:21 PM
RE: Odd noise - by Charles P - 22-03-2018, 01:43 PM
RE: Odd noise - by Charles P - 22-03-2018, 03:11 PM
RE: Odd noise - by Alan - 22-03-2018, 04:38 PM
RE: Odd noise - by Charles P - 22-03-2018, 04:44 PM
RE: Odd noise - by Zetomagneto - 23-03-2018, 08:55 PM
RE: Odd noise - by Charles P - 23-03-2018, 11:31 PM
RE: Odd noise - by Austin in the Shed - 24-03-2018, 05:48 AM
RE: Odd noise - by Charles P - 24-03-2018, 06:26 AM
RE: Odd noise - by "Slack Alice" Simon - 24-03-2018, 08:15 AM
RE: Odd noise - by Tony Press - 24-03-2018, 09:34 AM
RE: Odd noise - by Ruairidh Dunford - 24-03-2018, 09:46 AM
RE: Odd noise - by Tony Press - 24-03-2018, 11:55 AM
RE: Odd noise - by Ruairidh Dunford - 24-03-2018, 12:03 PM
RE: Odd noise - by Austin in the Shed - 24-03-2018, 12:55 PM
RE: Odd noise - by Charles P - 24-03-2018, 01:30 PM
RE: Odd noise - by Tony Press - 24-03-2018, 11:33 PM
RE: Odd noise - by Ruairidh Dunford - 24-03-2018, 01:36 PM
RE: Odd noise - by Zetomagneto - 24-03-2018, 02:34 PM
RE: Odd noise - by Charles P - 24-03-2018, 04:15 PM
RE: Odd noise - by Ruairidh Dunford - 25-03-2018, 09:01 AM
RE: Odd noise - by Charles P - 25-03-2018, 10:01 AM
RE: Odd noise - by Ruairidh Dunford - 25-03-2018, 10:42 AM
RE: Odd noise - by Dave Wortley - 25-03-2018, 01:02 PM
RE: Odd noise - by Tony Press - 25-03-2018, 11:32 PM
RE: Odd noise - by Dave Wortley - 26-03-2018, 05:55 PM
RE: Odd noise - by dickie65 - 26-03-2018, 06:20 PM
RE: Odd noise - by Tony Press - 27-03-2018, 04:22 AM
RE: Odd noise - by Charles P - 26-03-2018, 06:26 PM
RE: Odd noise - by Bob Culver - 09-04-2018, 02:28 AM
