Gear crunch - 1st and 2nd
I’m new to Seven (but not classic car) ownership. I have a 1935 Ruby.
I understand the requirement for double de-clutching to facilitate smooth gear changes and to try and change gear at the correct speed.
I am generally able to get a smooth change up and down between 3 and 4.
However from idle I struggle to engage 1st, 2nd and reverse no matter how many times I depress the clutch. More often than not there’s a crunch, but not always. It’s the same story going from 1st to 2nd (though it’s not as bad, I think I’ve figured the best speed and double de-clutch technique) and when going down from 3rd to 2nd (again not generally as bad as when the car is idling).
Any advice on what I could do to improve this would be appreciated. I’m not sure where to start.
Gear crunch - 1st and 2nd - by emleyj - 21-06-2022, 02:59 PM
RE: Gear crunch - 1st and 2nd - by Reckless Rat - 21-06-2022, 04:04 PM
RE: Gear crunch - 1st and 2nd - by Ivor Hawkins - 21-06-2022, 04:19 PM
RE: Gear crunch - 1st and 2nd - by emleyj - 21-06-2022, 06:21 PM
RE: Gear crunch - 1st and 2nd - by Ivor Hawkins - 21-06-2022, 06:35 PM
RE: Gear crunch - 1st and 2nd - by John Cornforth - 21-06-2022, 06:55 PM
RE: Gear crunch - 1st and 2nd - by Howard Wright - 21-06-2022, 08:08 PM
RE: Gear crunch - 1st and 2nd - by Reckless Rat - 21-06-2022, 08:09 PM
RE: Gear crunch - 1st and 2nd - by emleyj - 21-06-2022, 08:15 PM
RE: Gear crunch - 1st and 2nd - by Reckless Rat - 21-06-2022, 08:35 PM
RE: Gear crunch - 1st and 2nd - by Lowbarn - 22-06-2022, 10:00 AM
RE: Gear crunch - 1st and 2nd - by Nick Turley - 22-06-2022, 11:40 AM
RE: Gear crunch - 1st and 2nd - by AustinWood - 22-06-2022, 01:19 PM
RE: Gear crunch - 1st and 2nd - by Lowbarn - 22-06-2022, 01:34 PM
RE: Gear crunch - 1st and 2nd - by Reckless Rat - 22-06-2022, 01:46 PM
RE: Gear crunch - 1st and 2nd - by John Cornforth - 22-06-2022, 03:05 PM
RE: Gear crunch - 1st and 2nd - by Colin Wilks - 22-06-2022, 08:16 PM
RE: Gear crunch - 1st and 2nd - by emleyj - 23-06-2022, 08:20 AM
RE: Gear crunch - 1st and 2nd - by emleyj - 19-07-2022, 08:52 AM
