Camshaft end play
From the picture it looks as though it is the locking bolt that is the problem and the bush is probably moving with the camshaft rather than the camshaft moving in the bush. It is possibly both. The locking of the bush must be fixed before the movement of the camshaft in the bush can be assessed.
I agree that the locking bolt should be hex or cap head. I've had too many leaking through that bolt in the past. I have also had the camshaft feed block necessitating removal of the bush. It's simpler and easier.
Tap 5/16" BSF into the bush to make sure it's firmly locked. The original peg system is poor.
Camshaft end play - by Sneezerap - 16-03-2018, 09:23 PM
RE: Camshaft end play - by Ian Williams - 16-03-2018, 10:38 PM
RE: Camshaft end play - by Stuart Giles - 16-03-2018, 11:09 PM
RE: Camshaft end play - by Sneezerap - 17-03-2018, 12:54 AM
RE: Camshaft end play - by Ian Williams - 17-03-2018, 03:58 AM
RE: Camshaft end play - by Ian Williams - 17-03-2018, 06:39 AM
RE: Camshaft end play - by NickB - 17-03-2018, 08:12 AM
RE: Camshaft end play - by Chris KC - 17-03-2018, 08:54 AM
RE: Camshaft end play - by Steve Jones - 21-03-2018, 08:21 PM
RE: Camshaft end play - by Sneezerap - 21-03-2018, 10:34 PM
RE: Camshaft end play - by Hedd Jones - 21-03-2018, 06:32 PM
RE: Camshaft end play - by Stuart Giles - 21-03-2018, 11:39 PM
RE: Camshaft end play - by Chris KC - 22-03-2018, 10:38 AM
RE: Camshaft end play - by Sneezerap - 22-03-2018, 12:02 PM
RE: Camshaft end play - by AustinWood - 22-03-2018, 06:49 PM
