Camshaft end play
(22-03-2018, 10:38 AM)Chris KC Wrote: I'm not sure why you'd want to remove it if it's assembled robustly in the first place.
I do not want to remove the bushing or the camshaft. The camshaft will move forward and backward when the timing gears are installed by 1/8"  Thus far it has destroyed the timing gears plus the fiber gear on the end of the generator/dynamo. Someone, apparently,  overhauled the motor about 30 years ago and did not do a bang up job. Motor ran well until the fiber gear end up with missing teeth.  If I can stabilize the camshaft, I will have a good running motor.
Camshaft end play - by Sneezerap - 16-03-2018, 09:23 PM
RE: Camshaft end play - by Ian Williams - 16-03-2018, 10:38 PM
RE: Camshaft end play - by Stuart Giles - 16-03-2018, 11:09 PM
RE: Camshaft end play - by Sneezerap - 17-03-2018, 12:54 AM
RE: Camshaft end play - by Ian Williams - 17-03-2018, 03:58 AM
RE: Camshaft end play - by Ian Williams - 17-03-2018, 06:39 AM
RE: Camshaft end play - by NickB - 17-03-2018, 08:12 AM
RE: Camshaft end play - by Chris KC - 17-03-2018, 08:54 AM
RE: Camshaft end play - by Steve Jones - 21-03-2018, 08:21 PM
RE: Camshaft end play - by Sneezerap - 21-03-2018, 10:34 PM
RE: Camshaft end play - by Hedd Jones - 21-03-2018, 06:32 PM
RE: Camshaft end play - by Stuart Giles - 21-03-2018, 11:39 PM
RE: Camshaft end play - by Chris KC - 22-03-2018, 10:38 AM
RE: Camshaft end play - by Sneezerap - 22-03-2018, 12:02 PM
RE: Camshaft end play - by AustinWood - 22-03-2018, 06:49 PM
