10-06-2022, 11:51 PM
(21-05-2022, 04:06 PM)Michael D Wrote: TRY HERE
https://www.austin7ulster.com/new%20parts.htm
for either side draught, 30 degrees semi downdraught or downdraught inlet manifold. I presume you'll want the 30 degree semi downdraught to go with that 1 1/4" SU (ex-Mini)
I'd recommend ordering the blue spring and the No 6 needle while you're at it although with my Rosengart a No 5 needle seems to do a better job (rebuilt engine just back from workshop now need to run in my engine... similar set up as you're planning exhaust manifold not Bunch of bananas but tubular 4 into 2 into 1)
I've bought several parts from Paul Armstrong and in my experience he's ok
Thank you for all for the suggestions. I have just ordered a manifold from these people. Paulwas very helpful when I called this afternoon and has been very prompt replying to e-mails.
Exhaust manifold next. ..
Regards,
Jamie.
