10-06-2022, 04:17 PM
Forgive me if you are already aware of this and all is, in fact, well but your throttle control rod makes me nervous.
Is the split pin underneath the threaded adjuster at the top as it appears to be?
I would have expected to see this
![[Image: throttle-rod.jpg]](https://i.postimg.cc/FRKY4MTL/throttle-rod.jpg)
As you can see the split pin passes through the slot in the top of the adjuster.
Apologies if I am teaching you to suck eggs!
Regards,
Stuart
Regards,
Stuart
