White Metal Bearings
Hi All
Modern High Performance Rods are Resized all the time because of stretch to keep them round for fitting Shells because the Tolerances are a lot tighter.
The rod and cap are machined not filed
My Thoughts on this are if you have that much wear to think about filing then you will also have wear on the crank pinĀ
so a rethink is in order if just wishing to keep engine running and not doing alot of hardĀ  miles filing caps and scraping is fine
a regrind and remetaling is the long term fix
Colin
NZ
White Metal Bearings - by Lowbarn - 07-06-2022, 05:55 PM
RE: White Metal Bearings - by David Stepney - 07-06-2022, 09:08 PM
RE: White Metal Bearings - by frequentflyer - 07-06-2022, 09:31 PM
RE: White Metal Bearings - by Lowbarn - 07-06-2022, 10:16 PM
RE: White Metal Bearings - by Howard Wright - 08-06-2022, 07:36 AM
RE: White Metal Bearings - by David Stepney - 08-06-2022, 07:41 AM
RE: White Metal Bearings - by ppearson - 08-06-2022, 09:28 AM
RE: White Metal Bearings - by Malcolm Parker - 08-06-2022, 04:41 PM
RE: White Metal Bearings - by Lowbarn - 08-06-2022, 06:20 PM
RE: White Metal Bearings - by David Stepney - 08-06-2022, 07:06 PM
RE: White Metal Bearings - by Dennis Nicholas - 09-06-2022, 11:11 AM
RE: White Metal Bearings - by David Stepney - 09-06-2022, 09:48 PM
RE: White Metal Bearings - by Colin Reed - 09-06-2022, 10:55 PM
