  • 1 Vote(s) - 5 Average
Original ulster engine rebuild
#61
Not the easiest job without a milling cutter.
I've welded and ground the slot, and made a longer peg.
My grinding wasnt 100% accurate, and has pushed the lever slightly toward the driver.
Not a bad thing though.
Now it is done, this is how much movement I have.
I've had to lease the ball of to show how little play there is
Just the dynamo and distrib left.
The job I was looking forward to the least.
There is good movement in the rotor arm, so gears could be warn.
Also there is movement between the distrib and dynamo.
I may have to try and find a better dynamo end, this is the bit I dont like. Disterbing a good working dynamo.
Original ulster engine rebuild - by Tony Betts - 05-05-2022, 09:13 PM
RE: Original ulster engine rebuild - by JonE - 07-05-2022, 08:14 PM
RE: Original ulster engine rebuild - by dickie65 - 07-05-2022, 08:23 PM
RE: Original ulster engine rebuild - by Dave Mann - 18-05-2022, 09:39 AM
RE: Original ulster engine rebuild - by Dave Mann - 18-05-2022, 02:45 PM
RE: Original ulster engine rebuild - by JonE - 19-05-2022, 12:49 PM
RE: Original ulster engine rebuild - by Humps - 30-05-2022, 03:02 AM
RE: Original ulster engine rebuild - by Dave Mann - 01-06-2022, 06:32 PM
RE: Original ulster engine rebuild - by Charles P - 02-06-2022, 08:56 PM
RE: Original ulster engine rebuild - by JonE - 02-06-2022, 10:27 PM
RE: Original ulster engine rebuild - by Charles P - 03-06-2022, 11:12 AM
RE: Original ulster engine rebuild - by JonE - 03-06-2022, 12:02 PM
RE: Original ulster engine rebuild - by Charles P - 03-06-2022, 12:54 PM
RE: Original ulster engine rebuild - by Charles P - 03-06-2022, 03:19 PM
RE: Original ulster engine rebuild - by JonE - 05-06-2022, 07:45 PM
RE: Original ulster engine rebuild - by Tony Betts - 07-06-2022, 01:54 PM
RE: Original ulster engine rebuild - by Erich - 13-06-2022, 02:03 AM
