  • 1 Vote(s) - 5 Average
Rear Shock Absorbers.
Thank you David for that explanation, much appreciated.
My original setup had original beachwood discs (one cut) with faint logo stamped onto surface and lignum vitae forward bush with 1/4 W bolts as link pins. The bolts had worn a thread in the link bushes so was glad to replace them with pegged pins!
No way could I get fibre washers and supplied bushes into the arm fork without some fettling and get spring washer,nuts and locking half nut to fit onto the link pin!
Seems to be stable when driven over bumps and I have a great place to test it on the Campbell Straight at a welknown motor and aircraft museum !
Rear Shock Absorbers. - by cwchrisp - 01-06-2022, 07:51 PM
RE: Rear Shock Absorbers. - by JonE - 02-06-2022, 07:38 AM
RE: Rear Shock Absorbers. - by Hedd_Jones - 02-06-2022, 09:03 AM
RE: Rear Shock Absorbers. - by cwchrisp - 02-06-2022, 09:17 AM
RE: Rear Shock Absorbers. - by stuartu - 02-06-2022, 04:42 PM
RE: Rear Shock Absorbers. - by cwchrisp - 02-06-2022, 08:58 PM
RE: Rear Shock Absorbers. - by JonE - 03-06-2022, 10:45 AM
RE: Rear Shock Absorbers. - by Terrytuned - 03-06-2022, 07:36 PM
RE: Rear Shock Absorbers. - by Ray White - 04-06-2022, 12:44 AM
RE: Rear Shock Absorbers. - by Mike Costigan - 04-06-2022, 08:40 AM
RE: Rear Shock Absorbers. - by JonE - 04-06-2022, 10:05 AM
RE: Rear Shock Absorbers. - by cwchrisp - 04-06-2022, 02:17 PM
RE: Rear Shock Absorbers. - by Tony Griffiths - 04-06-2022, 09:44 PM
RE: Rear Shock Absorbers. - by cwchrisp - 05-06-2022, 11:13 AM
RE: Rear Shock Absorbers. - by David Stepney - 05-06-2022, 11:32 AM
RE: Rear Shock Absorbers. - by cwchrisp - 05-06-2022, 02:25 PM
RE: Rear Shock Absorbers. - by Dennis Nicholas - 07-06-2022, 12:34 PM
RE: Rear Shock Absorbers. - by cwchrisp - 08-06-2022, 12:49 PM
RE: Rear Shock Absorbers. - by John Cornforth - 08-06-2022, 02:05 PM
RE: Rear Shock Absorbers. - by andrew34ruby - 08-06-2022, 03:57 PM
RE: Rear Shock Absorbers. - by Howard Wright - 08-06-2022, 04:50 PM
RE: Rear Shock Absorbers. - by cwchrisp - 08-06-2022, 09:23 PM
