04-06-2022, 02:17 PM
Could I please check again whether the pins should be really tight within the rubbers or allowing movement as implied by the youtube video?
If the rubber is squashed as hard as possible, then hardly any movement but nipped up as per Woodrow allows some movement.
Also, rubber as supplied with fibre washers either side forces the arm fork apart too much, hence the shortening of the rubber.
Any thoughts please?
