Fan pulley
#43
We supply a variety of flat belts (https://store.lathes.co.uk/belts) and the inside length is the way to go; we measure them laid flat and recommend the following method:
"On all systems, set the two pulleys nearly as close together as possible and measure the belt length as follows. Use either a non-stretch fabric dressmaker's tape or a long strip of paper that can be wrapped around the pulleys, overlapped and marked. Lay the paper flat and measure the length"
Belt Width:
The flat belt can be the full width of the pulley - with one exception, a pulley with side flanges. If flanges are fitted, leave a couple of mm clearance at each side or the belt will try to climb up one of the faces.
https://store.lathes.co.uk/measuring-drive-belts
Fan pulley - by Steve Bryant - 10-02-2022, 02:55 PM
RE: Fan pulley - by Ruairidh Dunford - 10-02-2022, 02:57 PM
RE: Fan pulley - by Howard Wright - 10-02-2022, 05:31 PM
RE: Fan pulley - by Ruairidh Dunford - 10-02-2022, 05:48 PM
RE: Fan pulley - by Howard Wright - 10-02-2022, 05:56 PM
RE: Fan pulley - by andrew34ruby - 10-02-2022, 07:59 PM
RE: Fan pulley - by Steve Bryant - 11-02-2022, 02:20 AM
RE: Fan pulley - by Bob Culver - 11-02-2022, 04:51 AM
RE: Fan pulley - by Ruairidh Dunford - 11-02-2022, 08:49 AM
RE: Fan pulley - by Austin in the Shed - 11-02-2022, 08:54 AM
RE: Fan pulley - by Marcus Ling - 11-02-2022, 09:07 AM
RE: Fan pulley - by Ruairidh Dunford - 11-02-2022, 09:12 AM
RE: Fan pulley - by Marcus Ling - 11-02-2022, 09:31 AM
RE: Fan pulley - by Ruairidh Dunford - 11-02-2022, 09:33 AM
RE: Fan pulley - by Marcus Ling - 11-02-2022, 09:35 AM
RE: Fan pulley - by Howard Wright - 11-02-2022, 09:35 AM
RE: Fan pulley - by Marcus Ling - 11-02-2022, 09:37 AM
RE: Fan pulley - by Steve Bryant - 11-02-2022, 02:19 PM
RE: Fan pulley - by Austin in the Shed - 11-02-2022, 03:35 PM
RE: Fan pulley - by Marcus Ling - 11-02-2022, 07:27 PM
RE: Fan pulley - by Ian Williams - 11-02-2022, 08:14 PM
RE: Fan pulley - by gord - 11-02-2022, 08:46 PM
RE: Fan pulley - by Ruairidh Dunford - 11-02-2022, 09:35 PM
RE: Fan pulley - by Steve Bryant - 12-02-2022, 03:39 AM
RE: Fan pulley - by Marcus Ling - 12-02-2022, 11:07 PM
RE: Fan pulley - by Steve Bryant - 13-02-2022, 12:14 AM
RE: Fan pulley - by Steve Bryant - 15-02-2022, 01:50 AM
RE: Fan pulley - by Bob Culver - 15-02-2022, 04:59 AM
RE: Fan pulley - by Hugh Barnes - 15-02-2022, 08:01 AM
RE: Fan pulley - by Graham Barker - 15-02-2022, 09:53 AM
RE: Fan pulley - by Hedd_Jones - 15-02-2022, 10:14 AM
RE: Fan pulley - by Ian Dunford - 15-02-2022, 02:25 PM
RE: Fan pulley - by Reckless Rat - 15-02-2022, 02:43 PM
RE: Fan pulley - by Bob Culver - 15-02-2022, 03:48 PM
RE: Fan pulley - by Reckless Rat - 15-02-2022, 04:01 PM
RE: Fan pulley - by Graham Barker - 15-02-2022, 06:43 PM
RE: Fan pulley - by Howard Wright - 15-02-2022, 07:06 PM
RE: Fan pulley - by Marcus Ling - 15-02-2022, 07:42 PM
RE: Fan pulley - by Dom Carlisle - 01-06-2022, 09:45 AM
RE: Fan pulley - by Reckless Rat - 01-06-2022, 09:51 AM
RE: Fan pulley - by Jeff Taylor - 01-06-2022, 11:09 AM
RE: Fan pulley - by Peter Naulls - 01-06-2022, 09:54 PM
RE: Fan pulley - by Tony Griffiths - 02-06-2022, 01:57 PM
RE: Fan pulley - by Charles P - 02-06-2022, 02:28 PM
