Speed quandry
Hi Rob and Jim and Vance
I must admit to feeling rather exposed at 50mph.  It’s a bit better since I slackened off the shock absorbers a bit ?.  As you say Rob it’s not so much directional stability as vulnerability.
Vance, your 35mph does sound like an ignition timing problem, however are you relying on the car’s speedo. Not accurate at the best of times. I’d also check the brakes for binding as downhill you shouldn’t be too dependent on the engine !
Speed quandry - by Vancevr - 29-05-2022, 02:31 AM
RE: Speed quandry - by Bob Culver - 29-05-2022, 07:38 AM
RE: Speed quandry - by squeak - 29-05-2022, 08:42 AM
RE: Speed quandry - by Mike Costigan - 29-05-2022, 10:41 AM
RE: Speed quandry - by Colin Reed - 29-05-2022, 11:18 AM
RE: Speed quandry - by Mike Costigan - 29-05-2022, 11:21 AM
RE: Speed quandry - by Reckless Rat - 29-05-2022, 11:59 AM
RE: Speed quandry - by robert regan - 29-05-2022, 12:07 PM
RE: Speed quandry - by AustinWood - 29-05-2022, 12:40 PM
RE: Speed quandry - by robert regan - 29-05-2022, 01:59 PM
RE: Speed quandry - by Howard Wright - 29-05-2022, 03:44 PM
RE: Speed quandry - by Bob Culver - 29-05-2022, 10:22 PM
RE: Speed quandry - by Vancevr - 02-06-2022, 07:37 PM
RE: Speed quandry - by David Stepney - 02-06-2022, 08:04 PM
