Thermosyphon warming process
#28
You are right, I have forgotten about the heat lost in the exhaust. It seems a better estimate of where the energy from combustion goes would be, as you say, 1/3 mechanical work, 1/3 heat lost in the exhaust gases, and 1/3 removed by the cooling system.
I have measured the top temperature in the radiator in the past, and the temperature of the bottom hose was estimated - it was about as warm as bath water after a run. So the temperatures are about right? (Ambient temperature was about 15 degrees.) Therefore, taking the above calculation where 7.6KW is lost through the radiator, and the 1/3, 1/3, 1/3 split this would correspond to a useful work output of 7.6 KW which is 10.2 bhp - so the engine would need to be working harder to produce that heat load on the radiator and the flows given above - perhaps a speed of more like 40 mph?
Thermosyphon warming process - by Andy Bennett - 11-05-2022, 08:28 PM
RE: Thermosyphon warming process - by Nick Salmon - 12-05-2022, 07:08 AM
RE: Thermosyphon warming process - by AustinWood - 12-05-2022, 12:50 PM
RE: Thermosyphon warming process - by Bob Culver - 12-05-2022, 08:54 PM
RE: Thermosyphon warming process - by Mark Dymond - 13-05-2022, 01:07 PM
RE: Thermosyphon warming process - by Bob Culver - 14-05-2022, 10:51 PM
RE: Thermosyphon warming process - by Bob Culver - 17-05-2022, 08:32 PM
RE: Thermosyphon warming process - by Bob Culver - 17-05-2022, 11:54 PM
RE: Thermosyphon warming process - by Dave Mann - 23-05-2022, 08:58 AM
RE: Thermosyphon warming process - by Mark Dymond - 24-05-2022, 01:11 AM
RE: Thermosyphon warming process - by Colin Morgan - 24-05-2022, 07:31 AM
RE: Thermosyphon warming process - by Dave Mann - 24-05-2022, 08:35 AM
RE: Thermosyphon warming process - by Dave Mann - 28-05-2022, 02:03 PM
