Help needed please pdq on electric horn….
Thank you to Gary and Graham all good now.
Did wire the horn directly onto the battery and it did bleat very timidly, but it was better than nothing at all, so in the end stripped the horn down and cleaned up the contacts with 1000 grit W&D and made sure it all went back in the correct order.
Getting setting of the armature took a lot of trial and error but all good in the end, horn is now many decibels louder than it ever was. Result.
Could not find any makers mark anywhere on the unit, although there was a recessed area on the rear of the horn body, where you might have expected to see an inscription of some kind or a label but that had long since gone.
Thanks again
RE: Help needed please pdq on electric horn…. - by Denis Sweeney - 19-05-2022, 05:06 PM
