Ruby idle speed
Have you checked the flatness of the carb flange? I recently found bowing  on the carburettor flange was allowing an air leak between it and the manifold was enough to make idleadjustments impossible to set reliably. Lapping this flange flat again could well solve it.
Certainly worth investigating before you do anything more invasive on the carb itself. There's usually a simple solution to what appears to be a more complex problem!
Good luck  Bob
Ruby idle speed - by Peter Naulls - 17-05-2022, 09:50 PM
RE: Ruby idle speed - by Nick Lettington - 17-05-2022, 09:57 PM
RE: Ruby idle speed - by Peter Naulls - 18-05-2022, 07:56 AM
RE: Ruby idle speed - by Nick Lettington - 18-05-2022, 08:14 AM
RE: Ruby idle speed - by John Mason - 18-05-2022, 08:32 AM
RE: Ruby idle speed - by Peter Naulls - 18-05-2022, 09:05 PM
RE: Ruby idle speed - by squeak - 18-05-2022, 11:21 PM
RE: Ruby idle speed - by Peter Naulls - 19-05-2022, 09:32 AM
RE: Ruby idle speed - by Bob Kneale - 19-05-2022, 10:18 AM
RE: Ruby idle speed - by A G Wood - 20-05-2022, 02:01 AM
RE: Ruby idle speed - by Peter Naulls - 26-05-2022, 08:28 PM
RE: Ruby idle speed - by Malcolm Parker - 26-05-2022, 08:57 PM
RE: Ruby idle speed - by Peter Naulls - 27-05-2022, 08:11 AM
RE: Ruby idle speed - by Howard Wright - 27-05-2022, 08:15 AM
RE: Ruby idle speed - by Peter Naulls - 27-05-2022, 10:40 PM
