3-Speed Gearbox Queries.
Hi,
Shortly I think I will have to take the engine out of my Ulsteroid to try to fix the oil leaks I have been ignoring.
Whilst the 3-speed gearbox is out I'd like to improve the oil-tightness around the input shaft and some while ago I did buy a modern lip seal from one of the cherished suppliers which I naively thought could be fitted without any machining.    The reason I thought this was that there was some info on the Dorset Austin Seven Club site which read:-
“A simple and cheap way to overcome this problem is, firstly, to renew the bearing and then insert a modern oil seal in the nose piece between the input bearing housing and the roller bearing.  This stops oil from reaching the worn quick thread.  There are 2 types of seal: either Payen NA080 or Payen NA092 will do the job and they are simply a press fit in the housing, It is a good idea to grease the new bearing as hopefully no oil should now reach it”.
Anyway, the seal I have is marked SC 1-1/8  1-7/8  ¼
So, does anyone know if this is the correct seal and if the gearbox front cover / nose piece which contains the quick thread needs to be machined to fit it?
At the same time I'd also like to do something about the baulking I often experience when changing from 2nd to top gear.  Any suggestions what may be causing this and what could potentially be done to improve matters.
Many thanks,
John.
3-Speed Gearbox Queries. - by John P - 18-05-2022, 05:08 PM
RE: 3-Speed Gearbox Queries. - by Howard Wright - 18-05-2022, 05:36 PM
RE: 3-Speed Gearbox Queries. - by Terrytuned - 18-05-2022, 08:05 PM
