Ruby idle speed
For some time the idle speed on the Ruby has been variable. I put it down to wear in the spindle but it now seems to have got much worse. I can set the speed and all is fine for a day or two, then it fails to idle, I increase it and find the next day it's over revving. I've marked the adjustment screw and it's not adjusting itself. I get the impression that when it idles slowly the mixture is richer.
The float chamber is clean, the valve is closing correctly and I have lapped the emulsion block and replaced the gasket. The flange gasket is also new.
Any ideas?
Ruby idle speed - by Peter Naulls - 17-05-2022, 09:50 PM
RE: Ruby idle speed - by Nick Lettington - 17-05-2022, 09:57 PM
RE: Ruby idle speed - by Peter Naulls - 18-05-2022, 07:56 AM
RE: Ruby idle speed - by Nick Lettington - 18-05-2022, 08:14 AM
RE: Ruby idle speed - by John Mason - 18-05-2022, 08:32 AM
RE: Ruby idle speed - by Peter Naulls - 18-05-2022, 09:05 PM
RE: Ruby idle speed - by squeak - 18-05-2022, 11:21 PM
RE: Ruby idle speed - by Peter Naulls - 19-05-2022, 09:32 AM
RE: Ruby idle speed - by Bob Kneale - 19-05-2022, 10:18 AM
RE: Ruby idle speed - by A G Wood - 20-05-2022, 02:01 AM
RE: Ruby idle speed - by Peter Naulls - 26-05-2022, 08:28 PM
RE: Ruby idle speed - by Malcolm Parker - 26-05-2022, 08:57 PM
RE: Ruby idle speed - by Peter Naulls - 27-05-2022, 08:11 AM
RE: Ruby idle speed - by Howard Wright - 27-05-2022, 08:15 AM
RE: Ruby idle speed - by Peter Naulls - 27-05-2022, 10:40 PM
