18-03-2018, 05:08 PM
(This post was last modified: 18-03-2018, 05:11 PM by Derek Sheldon.)
[attachment=2451][attachment=2452]As Lewis Carrol wrote “curiouser and curiouser “ as you can see from the photographs of my Rosengart , yours appears to be a bastardisation of Rosengart and Austin. The way I see it is .that you have two choices if you can’t fix what you have. Austin parts are more readily available, Rosengart parts will look more like you have. The dynamo housings are interchangeable as the hole centres are the same. You would then need an Austin fan assembly , having said that yours looks Austin.
Reckless, bang on the nail. It is a French number and from Calvados. Haven’t finished restoring it yet, have a British number plate to attach.
