Oil levels
(09-05-2022, 08:22 PM)Nick Turle Wrote: EP 140  for the back axle back axle fill to about quarter of an inch below full (use a bent bit of wire or cable tie to dip)
Don't listen to anyone putting you off EP oils they are a superior performance and do not dissolve brass or bronze as they used to do in the 60's.
Hope that is helpful to you.
If an EP oil has an API rating of either GL-4 or GL-5 then the sulphur is inactive and safe to use in boxes with bronze bearings.
Oil levels - by Denis Sweeney - 09-05-2022, 11:11 AM
RE: Oil levels - by Nick Turley - 09-05-2022, 08:22 PM
RE: Oil levels - by Denis Sweeney - 09-05-2022, 09:46 PM
RE: Oil levels - by Tony Griffiths - 10-05-2022, 12:00 AM
RE: Oil levels - by Colin Morgan - 10-05-2022, 04:07 PM
RE: Oil levels - by Denis Sweeney - 10-05-2022, 06:12 PM
RE: Oil levels - by Colin Morgan - 10-05-2022, 09:06 PM
RE: Oil levels - by A G Wood - 11-05-2022, 02:03 AM
RE: Oil levels - by Nick Salmon - 11-05-2022, 06:45 AM
RE: Oil levels - by Dave Mann - 11-05-2022, 09:04 AM
RE: Oil levels - by Bob Culver - 11-05-2022, 11:04 AM
RE: Oil levels - by Terrytuned - 11-05-2022, 01:01 PM
RE: Oil levels - by Jeff Taylor - 11-05-2022, 08:35 PM
RE: Oil levels - by Terrytuned - 11-05-2022, 09:14 PM
