  • 1 Vote(s) - 5 Average
Original ulster engine rebuild
hi Greig,
thanks for the plug.
ive just had valves come in as well.
im not sure about replacing everything? the valves are not burnt or bent. and i know they seat well. im looking at cleaning them. reseating them. and reaming the guides.
just replacing whats worn or worn out.
and yes it will have my slipper pistons fitted.
ive just had a customer fit the slipper pistons to his engine to replace JP pistons. he has already sed it runs quieter and cooler.
also the ulster rep ive just sold i was having problems with smoke from the build done by pigsty in 1995. the engine had never been run since its build. slipper pistons now fitted. everything solved.
im looking forward to see how they run in the ulster engine.
on the same subject, ive also had them fitted to the blown ulster.
jonE,
number 4 is last in line for oil supply,
im not sure if it is phoenix or alan.
alan was etched but i cant see it, and the early phoenix had no markings.
although, as you the relationship between the two. basically makes then the same thing.
tony
Original ulster engine rebuild - by Tony Betts - 05-05-2022, 09:13 PM
RE: Original ulster engine rebuild - by JonE - 07-05-2022, 08:14 PM
RE: Original ulster engine rebuild - by dickie65 - 07-05-2022, 08:23 PM
RE: Original ulster engine rebuild - by Tony Betts - 07-05-2022, 08:38 PM
RE: Original ulster engine rebuild - by Dave Mann - 18-05-2022, 09:39 AM
RE: Original ulster engine rebuild - by Dave Mann - 18-05-2022, 02:45 PM
RE: Original ulster engine rebuild - by JonE - 19-05-2022, 12:49 PM
RE: Original ulster engine rebuild - by Humps - 30-05-2022, 03:02 AM
RE: Original ulster engine rebuild - by Dave Mann - 01-06-2022, 06:32 PM
RE: Original ulster engine rebuild - by Charles P - 02-06-2022, 08:56 PM
RE: Original ulster engine rebuild - by JonE - 02-06-2022, 10:27 PM
RE: Original ulster engine rebuild - by Charles P - 03-06-2022, 11:12 AM
RE: Original ulster engine rebuild - by JonE - 03-06-2022, 12:02 PM
RE: Original ulster engine rebuild - by Charles P - 03-06-2022, 12:54 PM
RE: Original ulster engine rebuild - by Charles P - 03-06-2022, 03:19 PM
RE: Original ulster engine rebuild - by JonE - 05-06-2022, 07:45 PM
RE: Original ulster engine rebuild - by Erich - 13-06-2022, 02:03 AM
