This evening I have been making a 1933 clutch cover plate lighter and smaller in diameter as well as reducing its thickness in the area where the springs sit and a reduction in thickness of the outer flange where it bolts to the flywheel.
The flywheel has already been reduced in diameter and had most of the outer ring milled off leaving six posts to bolt the cover plate onto it.
I might do a bit of undercutting on the outside of the posts.
The next part in line for lathe time is the pressure plate, this might not have a lot removed from it but there is scope to bevel the corners and remove a bit from the back where the springs seat.
Yesterday I self isolated under the car, adjusted the clutch on the crossshaft, greased the front suspension, and the steering box.
On Thursday I will grease the rear springs tweek the shocks and check the back axle oil level and have another play on the lathe.
RE: What have you done today with your Austin Seven - by dickie65 - 27-04-2022, 08:57 PM
Users browsing this thread: Dave Trickett, 14 Guest(s)
