3 Bearing bearing
(26-04-2022, 07:54 PM)Henry Harris Wrote: Austin and Reliant shells are 15/16" wide. BMC A series seem to be 1 1/16" wide. Both are 1 3/4" dia.
The 998cc and 1098cc mains are 1 1/16" wide; the 803, 850 and 948cc shells are 1.187 (1 3/16") wide as I said earlier, the difference is pretty obvious in this photo after a quick rummage in my workshop.
[Image: 52031199947_a5cbd6beb8_z.jpg]
I would be interested if you manage to find any documentation that matches the number(s) on the shell with the part number of the bearing. None that I have seen have any correlation. eg. the wide main marked VP2744 part number of the set VP244; The narrow main marked VP 4499 has a part number VP733. This is more than idle curiosity, I have a couple of sets of new bearings here where the tab was missing from the box end when they came to me. I have not been able (using t'interweb) to find a part number or fitment for these.
3 Bearing bearing - by Henry Harris - 26-04-2022, 04:14 PM
RE: 3 Bearing bearing - by Hugh Barnes - 26-04-2022, 05:10 PM
RE: 3 Bearing bearing - by Steve Jones - 26-04-2022, 06:36 PM
RE: 3 Bearing bearing - by Stuart Giles - 26-04-2022, 06:45 PM
RE: 3 Bearing bearing - by Henry Harris - 26-04-2022, 07:54 PM
RE: 3 Bearing bearing - by Stuart Giles - 26-04-2022, 09:54 PM
RE: 3 Bearing bearing - by DavidL - 26-04-2022, 11:05 PM
RE: 3 Bearing bearing - by Stumpi - 27-04-2022, 07:52 AM
RE: 3 Bearing bearing - by Henry Harris - 27-04-2022, 08:02 AM
RE: 3 Bearing bearing - by Bob Culver - 27-04-2022, 11:15 AM
RE: 3 Bearing bearing - by Stuart Giles - 27-04-2022, 01:52 PM
