16-03-2018, 10:38 PM
Depends on why it is floating, clearance between the bush and gear should be 2 to 3 thou, if the bush is moving in the crankcase the locating pin can be modified to secure the bush. If you could put up pictures we could probably give you more specific advice on your own engine.
