2 bearing crank in 3 bearing case
#35
The tempering temp is typically in the 600C range, a red heat, unlikley to have been reached. Full heat retreatment sure to cause distortion. If nitrided important the layer is not removed, at least from radii. Dunno about metal sprayting and prep for, but chrome accentuates fatigue.
2 bearing crank in 3 bearing case - by Humps - 12-04-2022, 05:36 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 13-04-2022, 12:54 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 13-04-2022, 09:42 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 14-04-2022, 05:44 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 14-04-2022, 10:04 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 18-04-2022, 10:00 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 19-04-2022, 09:56 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 25-04-2022, 02:50 AM
RE: 2 bearing crank in 3 bearing case - by Bob Culver - 25-04-2022, 03:10 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 27-05-2022, 04:07 AM
