16-03-2018, 11:21 AM
If you are going to shim the front bearings, BMC (NOT BMW) Mini track rod end shims are the right diameter, and used to be available in many thicknesses, and getting shims which are already the right size is so much nicer than cutting from shim stock sheet.
Robert Leigh
Robert Leigh
