2 bearing crank in 3 bearing case
#23
No, but have yet to get the crank out of the case. Marcus did make one observation that the oil hole in the
 journal is blocked, and I always assumed this was white metal as a result of running the bearing, but a quick test with a Stanley knife proved that the blocking material is much harder than white metal?r
Thanks Ian, that certainly answers one question.
Keith
2 bearing crank in 3 bearing case - by Humps - 12-04-2022, 05:36 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 13-04-2022, 12:54 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 13-04-2022, 09:42 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 14-04-2022, 05:44 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 14-04-2022, 10:04 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 18-04-2022, 10:00 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 19-04-2022, 09:56 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 25-04-2022, 02:50 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 27-05-2022, 04:07 AM
