2 bearing crank in 3 bearing case
#22
(13-04-2022, 09:49 PM)Charles P Wrote:
(13-04-2022, 09:42 PM)Humps Wrote: A friend who has built a type 59 Bugatti motor virtually from scratch is advising laser welding for the crankshaft build-up. At the moment, this is the way I plan top go.
Do you know if the crank was nitrided?
The IKE site suggests they were EN40B, a nitriding steel, although the website may not be the most reliable source.
If it is nitrided then laser welding may not be advisable
Charles
The crankshaft we had made was EN40B. Not nitrided. Gunmetal bearings.
2 bearing crank in 3 bearing case - by Humps - 12-04-2022, 05:36 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 13-04-2022, 12:54 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 13-04-2022, 09:42 PM
RE: 2 bearing crank in 3 bearing case - by Hedd_Jones - 13-04-2022, 10:13 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 14-04-2022, 05:44 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 14-04-2022, 10:04 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 18-04-2022, 10:00 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 19-04-2022, 09:56 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 25-04-2022, 02:50 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 27-05-2022, 04:07 AM
