2 bearing crank in 3 bearing case
Many thanks for the helpful advice. The crankshaft has "ACS 09/10-14" etched into it if that assists in identification?
I can see that I'll probably have to bend the jets carefully and drill the conrods for better lubrication.
It's pretty hard to assess where the jets are spraying the oil, but I guess a length of wire inserted through the jet should give some indication of their direction? The engine was assembled by an acknowledged expert in that field.
Also, I'm finding it difficult posting photographs?
Thanks again,
Keith
2 bearing crank in 3 bearing case - by Humps - 12-04-2022, 05:36 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 13-04-2022, 12:54 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 13-04-2022, 09:42 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 14-04-2022, 05:44 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 14-04-2022, 10:04 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 18-04-2022, 10:00 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 19-04-2022, 09:56 PM
RE: 2 bearing crank in 3 bearing case - by Humps - 25-04-2022, 02:50 AM
RE: 2 bearing crank in 3 bearing case - by Humps - 27-05-2022, 04:07 AM
