Loctite advice needed
Hi
I have noticed with some plugs that the terminal is not quite threaded all the way down. You tighten the knurled nut but it stops at the end of the threaded part, leaving the spade terminal not as tight as it could be.
My solution is to add a plain washer about 40 thou thick, plus a crinkle washer to resist vibration
Loctite advice needed - by Rick F - 05-04-2022, 11:56 PM
RE: Loctite advice needed - by A G Wood - 06-04-2022, 12:31 AM
RE: Loctite advice needed - by Duncan Grimmond - 06-04-2022, 08:09 AM
RE: Loctite advice needed - by Malcolm Parker - 06-04-2022, 08:13 AM
RE: Loctite advice needed - by Steve kay - 06-04-2022, 08:20 AM
RE: Loctite advice needed - by Chris Garner - 06-04-2022, 08:41 AM
RE: Loctite advice needed - by Steve kay - 06-04-2022, 08:49 AM
RE: Loctite advice needed - by A G Wood - 06-04-2022, 10:26 AM
RE: Loctite advice needed - by Steve kay - 06-04-2022, 10:45 AM
RE: Loctite advice needed - by Rick F - 06-04-2022, 10:49 AM
RE: Loctite advice needed - by John Cornforth - 06-04-2022, 11:46 AM
RE: Loctite advice needed - by Martin Baker - 06-04-2022, 11:51 AM
RE: Loctite advice needed - by Henry Harris - 06-04-2022, 02:23 PM
RE: Loctite advice needed - by A G Wood - 06-04-2022, 11:25 PM
