05-04-2022, 10:35 AM
(05-04-2022, 09:24 AM)John Mason Wrote: I have a spare A7 condenser wired up with two fly leads with crocodile clips. One to the body and the other to the terminal. All well insulated with tape. I carry it as a spare and it can be clipped on if required without removing the exsisting condenser. It is also good for testing out suspect condensers.If the original condenser is failing with old age it's likely to be short circuiting internally.
John Mason.
Fitting another condenser externally without disconnecting the original isn't going to do anything to help.
