Effect of failing/failed condensor?
You can add another condenser externally, just to check.
I go to my local car spares place and buy any condenser with a wire lead at one end and a mounting tag at the other.
The wire goes on to the connection on the dizzy and the tag tucks under a cylinder head washer.
If the car's running improves - you know what the problem is.
RE: Effect of failing/failed condensor? - by "Slack Alice" Simon - 04-04-2022, 12:13 PM
