One of those days in the workshop!
No Bob, as I said, I attached the gearbox to the engine and put the two into the car together.
Yes Hedd that is my memory of previous times, thanks I will try removing the throttle shaft in case that helps.
I cant help thinking that in order to see the timing mark on the flywheel, the cover has to be removed, so surely this would have to be accomplished without major dismantling?
RE: One of those days in the workshop! - by Oxford Jack - 29-03-2022, 10:24 PM
