Fibre washers.
(28-03-2022, 10:53 AM)Andy Bennett Wrote: i had the sane problem and replaced the fibre washer with a dowty one following recommendations here and all has been good since.
Andy
+1 , and they don't need a lot of torque to achieve a seal. Just remember if you're buying online that they're sized BSP
(28-03-2022, 09:59 PM)Hedd_Jones Wrote:
(28-03-2022, 05:48 PM)SlackĀ Alice Wrote: Screw grade Loctite or similar will make a petrol proof joint, without needing to overtighten fragile components.
Because it is only screw grade, it doesn't make the joint hard to undo.
Purple?
From what I recall, most grades of Loctite will interchange to an extent. Technically speaking 569 & 567 are sealers intended for threaded joints, 567 is intended for threaded joints also but it also works well in a face situation, which is what you have I think Hedd? 290 is a wick in grade that has got me out of a 'situation' before, it works very well with pinholes, hairline cracks and weld porosity.
Fibre washers. - by Hedd_Jones - 28-03-2022, 09:48 AM
RE: Fibre washers. - by Andy Bennett - 28-03-2022, 10:53 AM
RE: Fibre washers. - by Rick F - 28-03-2022, 11:15 AM
RE: Fibre washers. - by Hugh Barnes - 28-03-2022, 11:50 AM
RE: Fibre washers. - by Graham Barker - 28-03-2022, 07:18 PM
RE: Fibre washers. - by Ian Williams - 28-03-2022, 08:03 PM
RE: Fibre washers. - by Bob Culver - 28-03-2022, 08:36 PM
RE: Fibre washers. - by Hedd_Jones - 28-03-2022, 09:59 PM
RE: Fibre washers. - by A G Wood - 28-03-2022, 10:52 PM
RE: Fibre washers. - by Hedd_Jones - 29-03-2022, 08:23 AM
