Diff pinion thrust bearings
Thanks Tony
In the original diagrm the sleeve appeared separate from the torque tube ...and not continuous! it appears surprising thin.
Although not shown presumably adjustment is by shims as later. I was puzzling how the thread could be the adjustment?
All the other depictions, as with many Seven diagrams,  are self evident, although it is surprisng how few seem to closely study them. Prime  example the hub diagrams. Admittedly matching diagram to car can be challenging.
A component for which diagrams somewhat lacking are the dynamos, although Woodrow and exploded diags kindly supplied on here assist.
Diff pinion thrust bearings - by Nick Mayne - 07-03-2022, 10:46 PM
RE: Diff pinion thrust bearings - by Tony Press - 08-03-2022, 01:52 AM
RE: Diff pinion thrust bearings - by Bob Culver - 08-03-2022, 06:57 AM
RE: Diff pinion thrust bearings - by Nick Mayne - 08-03-2022, 01:50 PM
RE: Diff pinion thrust bearings - by Stuart Giles - 08-03-2022, 11:09 PM
RE: Diff pinion thrust bearings - by Nick Mayne - 09-03-2022, 04:04 PM
RE: Diff pinion thrust bearings - by Stuart Giles - 09-03-2022, 04:41 PM
RE: Diff pinion thrust bearings - by Steve Jones - 09-03-2022, 05:32 PM
RE: Diff pinion thrust bearings - by Bob Culver - 09-03-2022, 07:32 PM
RE: Diff pinion thrust bearings - by Nick Mayne - 11-03-2022, 01:22 PM
RE: Diff pinion thrust bearings - by Stuart Giles - 11-03-2022, 01:57 PM
RE: Diff pinion thrust bearings - by Nick Mayne - 21-03-2022, 02:52 PM
RE: Diff pinion thrust bearings - by Stuart Giles - 21-03-2022, 03:56 PM
RE: Diff pinion thrust bearings - by Tony Press - 21-03-2022, 10:59 PM
RE: Diff pinion thrust bearings - by Bob Culver - 21-03-2022, 11:42 PM
