Diff pinion thrust bearings
As tight as you can get it, many pinions are damaged/destroyed when this nut comes loose causing the pinion to wander in towards the Crownwhee centreline. To allow me to get it really tight I clamp the pinion in a pipe vice when I am tightening this nut -I also Loctite it rather than use the soft tab washer that the factory used.
Diff pinion thrust bearings - by Nick Mayne - 07-03-2022, 10:46 PM
RE: Diff pinion thrust bearings - by Tony Press - 08-03-2022, 01:52 AM
RE: Diff pinion thrust bearings - by Bob Culver - 08-03-2022, 06:57 AM
RE: Diff pinion thrust bearings - by Nick Mayne - 08-03-2022, 01:50 PM
RE: Diff pinion thrust bearings - by Stuart Giles - 08-03-2022, 11:09 PM
RE: Diff pinion thrust bearings - by Nick Mayne - 09-03-2022, 04:04 PM
RE: Diff pinion thrust bearings - by Stuart Giles - 09-03-2022, 04:41 PM
RE: Diff pinion thrust bearings - by Steve Jones - 09-03-2022, 05:32 PM
RE: Diff pinion thrust bearings - by Bob Culver - 09-03-2022, 07:32 PM
RE: Diff pinion thrust bearings - by Nick Mayne - 11-03-2022, 01:22 PM
RE: Diff pinion thrust bearings - by Stuart Giles - 11-03-2022, 01:57 PM
RE: Diff pinion thrust bearings - by Nick Mayne - 21-03-2022, 02:52 PM
RE: Diff pinion thrust bearings - by Stuart Giles - 21-03-2022, 03:56 PM
RE: Diff pinion thrust bearings - by Tony Press - 21-03-2022, 10:59 PM
RE: Diff pinion thrust bearings - by Bob Culver - 21-03-2022, 11:42 PM
