drills for stainless
You need to make any drill cut not rub. Rubbing greats the heat and takes the edge off the drill. Goinig in with a smaller pilot hole helps as does relieving the drill point. Good quality cutting oil is a must as well. The force required to make much above a standard 5mm diameter drill cut its own hole in a bit of 316 will be on the limit of pressure you can apply with a hand drill.
drills for stainless - by JonE - 13-03-2022, 09:15 AM
RE: drills for stainless - by Howard Wright - 13-03-2022, 09:51 AM
RE: drills for stainless - by Charles P - 13-03-2022, 09:55 AM
RE: drills for stainless - by Austin in the Shed - 13-03-2022, 10:10 AM
RE: drills for stainless - by JonE - 13-03-2022, 10:14 AM
RE: drills for stainless - by Stuart Giles - 13-03-2022, 10:29 AM
RE: drills for stainless - by Howard Wright - 13-03-2022, 10:32 AM
RE: drills for stainless - by Hedd_Jones - 13-03-2022, 10:43 AM
RE: drills for stainless - by Charles P - 13-03-2022, 11:05 AM
RE: drills for stainless - by Austin in the Shed - 13-03-2022, 11:14 AM
RE: drills for stainless - by Duncan Grimmond - 13-03-2022, 12:18 PM
RE: drills for stainless - by frequentflyer - 13-03-2022, 06:33 PM
RE: drills for stainless - by merlinart - 13-03-2022, 06:51 PM
RE: drills for stainless - by Duncan Grimmond - 13-03-2022, 07:31 PM
RE: drills for stainless - by dickie65 - 13-03-2022, 07:38 PM
RE: drills for stainless - by Bruce Young - 18-03-2022, 12:15 AM
