drills for stainless
Hi Jon
I use standard HS drills (Bosch as it happens).  I have a metric set in 0.5mm increments and an Imperial set (not Bosch).  Almost all the time the metric in 0.5 increments are OK and if you need more accuracy then I go to the nearest size then use a reamer (by hand).
Hope I’m not teaching Granny etc…. But sharp drills are vital!  If you don’t have one, buy a bench grinder and learn how to set the right angle. Also punch the hole first and use progressively bigger drills starting small.  A drill press is invaluable and I set mine to a low speed which seems to work best.
Hope this helps
drills for stainless - by JonE - 13-03-2022, 09:15 AM
RE: drills for stainless - by Howard Wright - 13-03-2022, 09:51 AM
RE: drills for stainless - by Charles P - 13-03-2022, 09:55 AM
RE: drills for stainless - by Austin in the Shed - 13-03-2022, 10:10 AM
RE: drills for stainless - by JonE - 13-03-2022, 10:14 AM
RE: drills for stainless - by Stuart Giles - 13-03-2022, 10:29 AM
RE: drills for stainless - by Howard Wright - 13-03-2022, 10:32 AM
RE: drills for stainless - by Hedd_Jones - 13-03-2022, 10:43 AM
RE: drills for stainless - by Charles P - 13-03-2022, 11:05 AM
RE: drills for stainless - by Austin in the Shed - 13-03-2022, 11:14 AM
RE: drills for stainless - by Duncan Grimmond - 13-03-2022, 12:18 PM
RE: drills for stainless - by frequentflyer - 13-03-2022, 06:33 PM
RE: drills for stainless - by merlinart - 13-03-2022, 06:51 PM
RE: drills for stainless - by Duncan Grimmond - 13-03-2022, 07:31 PM
RE: drills for stainless - by dickie65 - 13-03-2022, 07:38 PM
RE: drills for stainless - by Bruce Young - 18-03-2022, 12:15 AM
